Hello, I’m new to KS and have searched the forum and web for guidance on creating a streaky glass material, but I haven’t found a clear explanation.
Unfortunately, I can’t find high-resolution images of streaky glass sheets to use as a reference, which would be a great starting point. These sheets typically consist of two colors of opal glass mixed together, sometimes even blended with transparent glass. I believe I need to use a Color Composite node in the material graph, but I’m unsure how to set it up or connect it properly. Any help or guidance would be greatly appreciated. Thank you!
Example of this glass:
